Ok, ever since i bought this car i hated how the battery would just wobble around, and how i could not visually check my coolant. Well i took care of all of that today. I have some pics here you can view. My battery is now solid as a rock and not going anywhere. The cheap coolant tank you see is fixing to be replaced with a clear gas tank i ordered which is about the same size, but i think it will fit even better. Oh and yes that is green antifreeze in a 1997! [img]graemlins/banana.gif[/img] Im really happy with the way this project went. pics are here >>> http://spaces.msn.com/members/Bobbyz...&_c=PhotoAlbum
Loose battery improvments
<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.Tags: None
im sure it would just break again, im the type of person if some thing breaks once or if i think its a bad set up i dont support the people that engineered it and buy another. plus i want to see my coolant<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Originally posted by mwh27:
call me crazy... but why not get a stock replacement fluid overfill/battery holder.....?
for 98+ camaro guys I made a strap from the factory bolt hole for the little "block" all the way to the headlight bracket-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
looks good / great idea, and I like the fact you can see the overflow tube and the amount in the canister without pulling the dipstick ... thanks man, you just gave me a new project.\'97 Firebird 3.8 ... 1/4 mile = 12.50 (minutes)
Thanks, just be careful not to damage any wires with the sharp edges of the freshly cut metal, thats why some of the metal pieces look long and some look short. I looks kinda like a little kid built it looking at the pics, but each one is cut and installed just where i wanted them to be.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
