coil pack - FirebirdV6.com/CamaroV6.com Message Board
coil pack
  • coil pack
    how do you know if your coil pack is starting to go.
    thanks, burtcam
    Re: coil pack
    In my case the engine developed a bad misfire. I would press the gas pedal and the car would not want to move, it would just bog down. Turned out one of the three pack was starting to go. I replaced all three because they are quite inexpensive.
      Re: coil pack
      my car just dies then it'll start up again. when it dies , i could hear the fuel pump humming when i turn on the ignition so i don't think its a fuel problem.
        Re: coil pack
        your car would have a misfire if it was going out. Dying engine sounds fuel related. Is it at idle or while you are driving?
        http://www.bowtiev6.com/
          Re: coil pack
          That does not sound like a coil pack.
            Re: coil pack
            while driving
              Re: coil pack
              thanks, burtcam
              take your multimeter and check the resistance
                Re: coil pack
                what he said... Look in a Haynes manual, it'll have the correct resistance values that you can compare yours to.
                2000 v6 a4 Camaro
