can someone expain ignition mods like "MSD DIS-4" - FirebirdV6.com/CamaroV6.com Message Board
  • can someone expain ignition mods like "MSD DIS-4"
    can someone explain these to me and what is there that i can do?
    i have a 96 3.8L
    <b>*§*Julian*§*</b><br />*~*~*~<br />2000 Grand Prix GTP -Daytona 500 Edition (only 2000 made) - Supercharged 3.8L V6<br /><br />1998 3.8L V6 A4 Firebird w/ W68 package, Y87, T-TOPS!<br /><br /><a href=\"http://myweb.usf.edu/~jadidona/index.html\" target=\"_blank\">MY SITE - CHECK IT!</a>
    they send more electricity, and give you control over ignition timing and advances.
      Yes, it will give you some control over timing. It will allow you to retard the timing, but not advance it. It generates multiple sparks under 3000 rpm giving your car a better chance at combustion of the air/fuel mix. Over 3000 rpm, it generates one big powerful spark. This type of ignition system would be a real benefit when generating power in the upper rpms. I for one, notice a performance increase from 1500 rpm on, with a noticeable "jolt" at 3000rpm.
      It is commonly believed on this board that the MSD DIS-4 offers no benefit on a naturally aspirated 3.8 Series II engine. This may be true on a basically stock car. I personally believe that once you start performance mods (i.e. air intake work,porting and polishing, performance chips that supply more fuel, etc.) the stock ignition will perform at a nominal level at best.
      I could go on and on about this mod and others, but it really depends on what you expect from basic "bolt-on" modifications. This is not a mod that's gonna snap your neck back like nitrous or a torque converter, but it helps if your goal is all-around performance. Shouldn't be done as a start-up mod.
      [ December 24, 2002: Message edited by: AMinor65 ]</p>
      <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
        hmmm... cuz i have B&B exhaust, SLP CAI, i just ordered Dee's TB Spacer
        so do u think it will help performance any?
          <blockquote>quote:</font><hr>Originally posted by SuprSpdDB7:
          <hr></blockquote>
          Couldn't hurt. This is how I analyze a mod. CAI=More Air/Velocity. B&B exhaust=better exhaust evacuation, more air coming in. Throttle body spacer. Cooler air=denser air=more air molecules. TB Spacer also equals an extention of intake plenum, which equals higher air velocity, which provides better atomization of fuel mix. More air coming in=more fuel added by PCM. Light that mixture with a bigger spark, more combustion. More combustion, bigger push on the cylinders. Bigger push, more power! That's the theory anyway. ;) To be honest with you, I would have never have gotten the MSD DIS-4 if I hadn't planned on upgraded coils, wires and plugs. I have the wires and plugs, but haven't installed them yet. Can't wait.
          I think my chip is helping also, with the richer mix. You gotta look at your whole system, and the principles behind a mod.
            http://mods.firebirdv6.com/msd/
            It's been sitting in our Modifications Encylopedia
            :( Sure would be nice if it got used ;)
            [ December 25, 2002: Message edited by: Dojo2000 ]</p>
            ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
              I used it way back.
                <blockquote>quote:</font><hr>Originally posted by Dojo2000:
                <hr></blockquote>
                woah... i have never seen it in there b4... it must be new
                (no.. i am being serious)
