cooling fan - FirebirdV6.com/CamaroV6.com Message Board
cooling fan
  • cooling fan
    I did the manual fan switch,on the low setting both fans come on half assed,and on the high setting one fan comes on really high.I wired it up just as the instuctions except I got the switch at ace hardware instead of radio shack.did I do something wrong?
    Re: cooling fan
    ok I just did the radio shack one and got the same thing
      Re: cooling fan
      High is both fans low is one fan.
        Re: cooling fan
        are both fans supposed to come on high because mine come on very softly and don't really do much,where as the low setting the fan comes on nice and strong.Am I missing something?
          Re: cooling fan
          odd, i did that manual fan switch thing also and low is half a**ed on both fans, while high is... well high on both fans. i would check the wires at the plugs of the fans. thats the first thing that popped into mind. just be patient, im sure you'll figure it out.
            Re: cooling fan
            ok so I tried everything to get both fans to turn on high with the switch.So I went ahead and bridged the high and low wires together and it seems to work.Now I just need to see if the fans will work with the switch off...Wish me luck!
              Re: cooling fan
              ok I got a trouble code from doing that,so I separated the wires again and still have the same problem.Does anyone knows what's going on?
                Re: cooling fan
                Sometimes saving money is not worth it, especially when it concerns something electrical. This is what I'm installing, and I'm an engineer.
                http://www.slponline.com/view_product.asp?P=63011
                You better REALLY know what you are doing when dealing with a wiring harness.
                Raven
                  Re: cooling fan
                  do u hav a really good ground because i installed an amp once with bad ground and thought it was junk but it turned out to be bad ground.
