PCM flash for 40mph lag? - FirebirdV6.com/CamaroV6.com Message Board
  • PCM flash for 40mph lag?
    Talked to viper he said my 40mph is from my pcm. Ganna call gm tommorrow see how much it is to flash it. any thoughts?
    How long does it take?
    How much money is it?
    Is there a noticeable boost?
    Does it give me a speed limiter?
    We got this thing its called RADAR LOVE.
    If gm does your pcm you will still have the speed limiter.
    You will get no boost from relashing the pcm by GM. If there is a problem causing your 40mph lag that resides in the pcm, that might be gone from reflashing.
    96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
