overheating - FirebirdV6.com/CamaroV6.com Message Board
overheating
  • #16
    Re: overheating
    Originally posted by zuko88
    yes im filling the radiator @ the radiator itself and not the resevoir. when i fill it i let the car idle for a good 10-15 mins and then top it off and close it. isnt that what "bleeding" is???
    NO, there is a Bleeder Valve on the thermostat housing
    You open it and let the air out!
    This is probably your problem!!
    There should be a BIG warning saying OPEN THE BLEEDER VALVE!!
    Danger to teh manif0ld captain!!!
    im reaching all the way to 260??? whatever the redline is. i've even passed it on long drives up the freeway.
    OMG!!!
    N00bs! Dont EVER let your coolant rise above the 215F mark!
    You wanna know how to destroy an engine this is it!!
    Hope your head gasket is still sealing!
    • #17
      Re: overheating
      no that is not how to bleed our systems. That only works on cars with the pressure cap on the reservoir and a sealed radiator. we have a bleeder screw just before the thermostat. This is probably why you are overheating. I hope you didn't toast your engine getting it so hot.
      2000 3.8 A4 Pewter Camaro
      • #18
        Re: overheating
        JINX! I am quick young grasshoppa
        • #19
          Re: overheating
          you'd be losing coolant, and/or having white smoke out the exhaust, and/or lack of power, and/or hydolock, and/or etc.
          • #20
            Re: overheating
            Originally posted by slow6
            OMG!!!
            :eek:
            how do i know if it still is sealing?
            • #21
              Re: overheating
              1 loss of coolant is a way to tell that its NOT sealing
              2 low cylinder pressures on a pressure test
              3 very white exhaust
              4 very clean cylinders and/or plugs
              ETC...
              • #22
                Re: overheating
                gotcha. no white smoke. no coolant loss. so far im okay.
                • #23
                  Re: overheating
                  ETC...
                  beat you old man
                  • #24
                    Re: overheating
                    bent connecting rod from hydrolocking FTW!
                    (dont ask me how I know)
                    • #25
                      Re: overheating
                      what????
                      • #26
                        Re: overheating
                        you have a connecting rod connecting your piston to your crankshaft. when you hydrolock, more liquid (coolant) in the cylinder than available compressible space, you bend that rod. very expensive. motor ending until repair.
                        • #27
                          Re: overheating
                          so if that was the case would the car still run???? cuz i havent noticed a diff in performance much.
                          • #28
                            Re: overheating
                            it might but doubtful. you would know something was wrong. If you are not missing coolant, I would only be concerned with bleeding your system.
                            • #29
                              Re: overheating
                              no very doubtful it would start
                              Just saying what COULD very easily happen to scare you so you wont choose to let it overheat again.
                              CLIFF NOTES: If overheating, turn it off!!
                              just watch your coolant temp, let it heat up to around the 195F area, then open the bleeder valve, keep it open till theres no more steam and just liquid coming out. refill radiator, repeat
                              • #30
                                Re: overheating
                                beat you old man
                                ME FTL!
                                typing > me :tdown:
