Hello, wasnt sure where to put this thread, and searched for a similiar thread, couldnt find one. I was just curious, for anyone who has done or knows someone, how much did it end up costing to do the conversion?
v6 to v8 conversion
This topic is closed.
Re: v6 to v8 conversion
They haven't made Z28's in over 5 years, so used.
Engine
Transmission
Wiring Harness
Engine Accessories (alternator, ps system, mounts, exhaust etc)
LS1 K member
LS1 front springs
Fuel system upgrades
Since the '98's wiring harness is different from the '99-'02 Fbodies, you'll need a '98 engine and trans to save you some trouble. Although it would still be a pita and take a while to do.
You're better off selling your car and buying a TA/Z28 rather than swapping the engine in.2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
there is no way you search and didn't come up with much :bs:
Originally posted by Greg94Red392Ummm my Ls1 6 Speed gets about 17mpg could probably get more if I wanted to.
To the OP, check this site out:
www.v6conversion.com
And unless you get the motor/trans for free, you will end up spending more on a swap then selling your car and buying a Z or T/A (or Fomula).Last edited by Shodown; 03-29-2007, 12:29 PM.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
And unless you get the motor/trans for free, you will end up spending more on a swap then selling your car and buying a Z or T/A (or Fomula).Red 1998 Camaro<br />Mods so far=<br />K&N
Originally posted by Stock98camaroYeah, but on the upside, you still get insurance for a v6. ;)sigpic
1997 Camaro RS A4
2006 Chevy Colorado
Guys, lets leave the gas talks and stuff for the lounge, not here. He doesn't want info on that stuff, only on doing the swap.
you would need to find the engine/pcm/kmember/trans/wiring harness/radiator and some other little things to make it work. Best bet is to find a totalled z28 donor car and swap everything from that to your v6.
Originally posted by 98PontiacFBHello, wasnt sure where to put this thread, and searched for a similiar thread, couldnt find one.
http://forum.camarov6.com/showthread...ls1+conversion
