alrite. today i was driving in the parking lot at the mall. and i found a parking and got out of the car. i turned and there was this trail of coolant that had dripped from my car the entire drive :mad: . the drainage plug thing from the bottom of the radiator had loosened or sumthin cuz thats where the coolant was leaking from. when i went to tighten it it just tightened a little more and the clicked and was loose again. u know. it would only thread so far and then be non-threated. i called pepboys and the dude was like, "u need a new radiator." and then i called napa and the chick said, "u can buy a push in plug or a new threaded plug." she also said that it is possible that i need a new radiator. i have the car parked at my uncles cuz he lives right by the mall, so dont worry about me driving it. i just wanted to know sum of the f-body's experts openions.
ANOTHER coolant system problem
Re: ANOTHER coolant system problem
heh
epoxy FTW!
Just be aware that there is 18+ psi of pressure pushing out!
(liquid and/or gas form)
I got ghetto riggin skillz like a mofo, boi, you dunno son
Maybe you could just put some gasket-maker or RTV or silicone
(high temp kind) on the threads THEN screw it in. fixed
let it dry
and DONT forget to bleed, Always bleeeedLast edited by slow6; 03-29-2007, 06:41 PM.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
try a new plug first before you get a new radiator and of course do not ghetto rig stuff
welll the plug was definately ONE of the problems. but u know how theres a spout that stix out by where the plug goes in? well i have coolant leaking out of that too. so im going to get this mechanic that i know to put the strongest leak/crack stuff to seal everything up until i can afford a new radiator.
if he is putting pellets in your system, he's dumber than you. those things are crap, do not fix leaks and cause some really good clogging problems. :)
