sparkplug help - FirebirdV6.com/CamaroV6.com Message Board
sparkplug help
  • sparkplug help
    whats up guys, Lets see. I have a 98 trans am, and need a tune up.So I went to Pep Boys to buy some AC Delco spark Plugs. The guy told me that the Spark Plugs have a Gap of 040, and to leave them like that, not to change them. My car needs the gap to be 060,I need to know if anything bad would happen to my car if I change it to 060. Should I just return them and buy another brand, or did the guy know what he was talking about. Right know im confused, I need to know what to do before I start. Oh the Spark Plugs are "AC Delco Iridium Spark Plugs."
    Thanks
    Seven
    Re: sparkplug help
    do not under any circumsances regap iridiams or platinums it weakens them to the point that and electrode breaking off wile there in you engine is likley get a different parts guy i know alot of people are using ngk tr6's with good success though
      Re: sparkplug help
      take them back and make him give you some ac delcos that are gapped properly. You are not suppose to regap those plugs as said
      2000 3.8 A4 Pewter Camaro
        Re: sparkplug help
        ok looks like i will take them back tomorrow. thanks alot guys.
          Re: sparkplug help
          must be you know a lot of guys that are FI and/or on the nitrous bottles. :) Those plugs are colder, gapped at .035 and made for the big power adder peeps.
          http://www.bowtiev6.com/
            Re: sparkplug help
            He probably meant TR55s
            ~97 3.8L V6 Camaro~
            A few things
            Only Member of Team Hooker?!?
              Re: sparkplug help
              cool thats what i just bought ngk tr55s.
                plug wires
                Can anyone tell me wich plug wires would work better for tr55 spark plugs.
                  Re: sparkplug help
                  That's what I have. I put them in after I seafoamed, and my car got abit better mileage, and abit more low end (now can chirp 2nd without really trying). nothing really noticable though....
                  ~97 3.8L V6 Camaro~
                  A few things
                    Re: plug wires
                    ummm...yea...doesn't really matter just don't get cheapos imo
                    AC Delco...MSD...
                    1999 Camaro Z/28
                    1973 Firebird Formula
                      Re: sparkplug help
                      Says who...other than the spark plug box? The idea that no platinum or iridium plug can be regaped is crazy.
                      Reality is that whether or not you can regap a platinum- or iridium-tipped plug depends on the plug's construction.
                      The double platinum ACDelcos, which were OE on most 04 and earlier engines, can be regaped because the only parts which are platinum are the little pucks which are laser-welded on the ends of the center and side electrodes. The side electrode, which is the part you bend slightly to change the gap, is made of typical plug material, a high-nickel content, steel alloy.
                      Many aftermarket iridium plugs, such as the Denso Iridium power IT20 pictured in the "Tom Henry RS" V6 project series at www.camarohomepage.com, is a "single iridium" tipped plug and can easily be regapped, simply by bending the ground electrode with the proper plug gapping tool. I run Denso IT20s or IT22s in every car I own and they're all regaped.
                      What you don't want to fool with in platinum tipped or iridium tipped plugs are any electrodes which are fine wire. The center electrodes on many Bosch and Densos are like that. But...no one modifies the center electrode on a plug anyway. Now, in the case of a plug with a fine wire ground electrode, then don't regap.
                        Re: sparkplug help
                        Anyone know why my plugs keep having a problem with high speed glazing?
                          Re: sparkplug help
                          Return the AC delco plugs and get some TR55IX's that is the iridium TR55 by NGK. They are a little pricey but worth it.
                          My old car.<br />2000 Firedird 5-Speed<br />1/4 E.T. 15.601 @ 88.659 w/2.411 60\'<br /><br />New car.<br />1999 T/A 6-Speed<br />1/4 E.T. 13.181 @ 106.971 w/2.15 60\'
