i have a 1994 firebird and it has started to leak coolant from a crack in a small pipe. the pipe is just below the intake manifold but above the top center belt pulley. the pipe comes from the engine and branches out 3 ways, two to some u-shaped hoses that appear to lead back to the engine and one bigger one to hose that leads somewhere on the passenger side. the coolant drips directly on the pulley and gets all over my belts and splatters on just about everything around it.
the coolant was brown and i thought it was oil at first...
what is that pipe called and where can i find a replacement?
