I have a 99 a4, stock transmission with overdrive. I was talking to my friends brother who just finished bulding a 69 Camaro, so he knows a lot about cars. he said if I worked on shifting through 1, 2, Drive, then overdrive i would actually be faster, then just keeping it in overdrive. Is he right?
shifting with an auto?
no..let the tranny do the work..you wont get any gain from trying to shift an auto [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
The only anvantage to shifting an automatic is that it won't shift too soon. Basically, you wind it out further. This works better with older cars. But, like V8 Killer replied, These newer cars have rev limiters, and it would shift anyway. So just let the trans do it's own thing. [img]graemlins/wavey.gif[/img]
By the way, its better on gas too. Not by much though.-Rick<br /><br />Bright White \'95 Firebird Convertible 3.4L A4 - Flowmaster American Thunder Cat-back, Zexel Torsen Posi-traction, Black Checkered Stripes, Clear Corners, Misc. Appearance Mods.<br /> <a href=\"http://www.cardomain.com/ride/2077741\" target=\"_blank\">http://www.cardomain.com/ride/2077741</a> <br /><br />AIM ID: AxSlane
theres a big difference between shifting the old-school auto trannies and the electronically controlled ones we have today. He is right, in the old trannies you can shift them manually, forcing them to hold higher rpms if you were racing or just screwing around. In the newer ones you will just tear them up. If you REALLY want to manually shift it, do a conversion and swap in a TH350, or rebuild yours with a full manual valve body.\'01 Mineral Grey SVT Cobra<br />-former F-body owner
You can also buy shift kits that will do the same thing to the 4L60E. They allow you to control which gear you are in all the time no matter what speed your doing or how many rpm's. Only downside is if I remember correctly, you have to downshift all the time because it wont shift itself if left in overdrive. It basically makes the 4L60E a manual transmission with a torque converter instead of a clutch.1995 Arctic White Camaro. 3.4L/A4<br /><br />\"Stupid men make mistakes, wise men learn from mistakes\"
actually, if you try to shift it yourself and dont keep shifting, it can sometimes not shift and your riding your rev limiter on your stocker tranny ;)
Why didnt you just get a manual in the first place if you wanted to shift [img]smile.gif[/img]<a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
shift kits dont allow you to shift an auto manually anymore than you can on a stock tranny, they just increase the firmness of each shift. I wouldnt recommend one without building the rest of the tranny, as it will increase wear and affect the lifespan of your otherwise stock tranny.... this is a debateable viewpoint though.
you can do it, i mean convert your 4L60E, buts its a full manual valvebody that needs to go in.... which means you need to do a full teardown and rebuild, I believe.\'01 Mineral Grey SVT Cobra<br />-former F-body owner
I was told not to install my trans go kit, due to the fact I would kill second gear really fast and the rest of the tranny after that. So, I am just waiting for rebuild time down the road and beef it up and install it then.Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
