Inline Fuel pump question - FirebirdV6.com/CamaroV6.com Message Board
  • Inline Fuel pump question
    Heya, if my in tank fuel pump was going, could i add an inline fuel pump instead? i know that that fuel pump is a B!tch to get to..
    Black 1995 3.4L V6 \"<b>THE BLACKBIRD</b>\"<br /><b>Performance Mods </b> K&N Fipk, Hypertech Underdrive pullies, Accell Coilpacks, and wires, rapidfire plugs,180 degree thermo, 1LE Tranny Mount, Z28 Catback W/crome tips B&M Ripper shifter<p><b>Appearance mods</b> 2 1/2% Limo tint all around, Blacked out taillights, turn signals, and side markers, red PONTIAC rear Inlay, 98+ style centerplate bird and graphic<p><b>Stereo System</b>Panasonic Cqdf 800u head unit, 2 MTX thunder 280 amps bridged, 2 Cerwin Vega AI 12\'s on the rear deck, 6x9\'s in the rear sail panels, Monsoon Door panels With Memphis Audio 6.5\" Coaxials and tweeters, 1 farad EFX cap.
    i would replace the pump in the tank. this pump has a filter sock on it that can get clogged sometimes, possibly lowering fuel pressure and volume. if you just throw an in-line pump on there, you're still sucking through the same dirty filter sock.
    ASE Master, L1, X1, C1. Instructor in automotive systems. 99 3800 4L60E with a few mods and a greatful dead sticker on the back window.
      IMO, your better off replacing the intank pump with something better. Adding an inline won't work how I think you want it to. If your fuel pump dies, you want to put the new one directly inline with the old, burned out one? I could be wrong here, but I think the old one would seize and not spin, thereby blocking the fuel if you tried to pull it from the same tubing farther down the line. Ya see what I mean? Besides, just do the intank, it's easier than you think and your thank yourself later. You can the Walbro 255lph pump for under $100.
      Tom
        Bird, what you say makes sense, but then why is it benefitial to run an inline pump to increase fuel flow in normal conditions? Wouldn't you be limited by the flow of the intank pump in that case as well?
          I could be wrong on this, but wouldn't it kinda just pull the stock pump harder? The only reason I wouldn't recommend what Red is talking about is that if the intank fuel pump is seized, no fuel will get past it. Anyone else have some thoughts on this?
            I am getting my fuel pump replaced here well as soon as the thing gets here from gmpartsdirect.com but the reason i have to get a new pump or should i say the entire sending unit is that some stupid little check valve went out in my tank, so my pump works good, except for the fact that i have no fuel pressure when i shut the car off. i spose the reason i am tellin you all this is the fact that there could be more wrong then just the pump there are alot of little pieces in the sending unit in the tank.
              Are their any other options for replacing the fuel pump, such as one from a Z28 or such.
              1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
                There are a few companies out there that make high flow replacement pumps. Walbro & Holley to name a few. At LS1 motorsports, they drilled the tank and put in -AN fittings with a Aeromotive 1000hp pump that is out of the tank mounted on the frame rail. They are running a turbo LS1, but it's a pretty sweet setup. Along with the pump, they have a Aeromotive high flow filter between the pump and the tank to make sure that they don't burn their pump up. This would be a lot of custom plumbing and the pump would be over kill, but it sure would be nice. It is the setup that I will be running when I put the LS1 in.
