Time to play NAME THAT SOUND! - FirebirdV6.com/CamaroV6.com Message Board
  • Time to play NAME THAT SOUND!
    ok so I took a 50sec clip of this sound, please listen to it and tell me what you think is the problem
    It is a '99 camaro 3.8 with about 87K miles on it
    recently I had a problem with the oil pressure regulator, it caused my oil pressure to shoot up and actually blow my oil filter right off(along with all of the oil in the engine) I shut off the motor before the oil pressure hit zero though.
    Although I have heard this sound a little bit before the above incident, It goes away once the engine gets hot.
    here is the link:
    http://s66.photobucket.com/albums/h2...t=CLIP0004.flv
    K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
    Re: Time to play NAME THAT SOUND!
    Sounds like a lifter to me.
      ^Agreed. At least...that what it sounds like. Pull the valve cover and have a look-see.
        i have a similar sound (not that bad tho)... what are you looking for under the valve cover? a gap b/w the lifter and rocker?
          yep, its a lifter.
          Phil
            so what do I look for when I take off the valve covers? also what will I probably need to replace? and will it damage other things if i keep driving it for a little while?
              wow i dont miss that sounds sure is a lifter mine didnt last much longer after it but i had a couple other tiny lil problems like my oil pump dieing completly
                hey im not mad, its just a good reason for me to upgrade
                  you cant get to the lifters just pulling valve covers though, you have to pull upper and lower intake to get to them i believe, have fun with that, there are worse things to be doing, but i still wouldnt want to
                    yea, tempo's too slow to be an exhaust leak...probably a lifter
                      is there any write up on how to do it? if not can someone give me a crash course on the steps to take?
                        that sound sucks. can u pinpoint which lifter it may be?
                          that'd be kinda hard to do just from listening to it, since all the lifters are like within 2 inches of one another
                            http://kennyislarge.com/files/lifter.pdf
                            http://kennyislarge.com/files/intake_lower.pdf
                            http://kennyislarge.com/files/intake_upper.pdf
                            http://kennyislarge.com/files/pushrod.pdf
                            i recommend you buy the gm si from me, its a lifesaver http://forum.camarov6.com/showthread.php?t=77003
