lights on, WHATS GOING ON! - FirebirdV6.com/CamaroV6.com Message Board
  • lights on, WHATS GOING ON!
    on my other car 2000, olds alero, the service vehicle soon, anti lock and trac off lights came on a few days ago and they remain on all the time. does anybody have any ideas what could cause this.
    THANKS, BURTCAM
    Re: lights on, WHATS GOING ON!
    sounds like suspension problem. Maybe brakes or something. Just go have it checked out. I think advance can hook it up and find the codes.
      Does the trac and anti lock lights come on when you start it without even driving? If so I would think that you maybe have a connection disconnected on a speed sensor or wheel bearing, or something like that. I would go get that code scanned but I would also climb under there and look for something to be disconnected. Be careful and good luck.
      Originally posted by kala
      TEAM BLACK!!!
      parting her out
        when i first start the car the lights are off but as soon as i start to go the very first time i put my foot on the brake the lights come on.
          I'd guess that one of your snesors have just crapped out and you will have to take it to dealer to figure out which one exactly or else it will be a crap shoot on guessing which one.
          TEAM BLACK!!!
          parting her out
            have to codes read
            2000 3.8 A4 Pewter Camaro
              can a bad speed sensor cause this problem? according to the haynes manual, a bed speed sensor can cause driveability problems whatever that means
                I don't know if it can cause it on an Alero but it can cause that problem on an Aztek. So I would Guess that it can but can't say for sure.
                TEAM BLACK!!!
                parting her out
                  i'm going to autozone this afternoon and get them to pull the code.
                    Check to make sure the brake lights are alll good on the rear . i know that can set an abc code .
