Does anyone know where the A/C temp. sensor is? I was told that could be what is wrong with my A/C???? I've already changed the pressure sensor by the freeon thingy!
You maybe wasteing your money by changing parts.You should get a set of gauges and see if you have freeon in your system. You have 3 sensors that could be bad or not.
Whoa man, don't just take the thermostat out. That can cause a whole mess of problems with cooling. Does your fan come on when you turn on the AC? Does it come on when the car is hot? Could be something wrong there. What temperature do you consider "running hot"?
David
1995 Nissan Hardbody King cab XE, 5-speed, 4 banger<p>Looking for the right Camaro...
its running about three centimeters past 210.which is not normal for my car...my AC cuts off when I go faster then 60...also, my car runs hotter the faster I go..I was kidding on the thermostat part..
Landon<br />2002 Black Z28<br /><a href=\"http://community.webshots.com/user/02blackzzz\" target=\"_blank\">http://community.webshots.com/user/02blackzzz</a> <br />SLP Whisper Lid, Chip, Magnaflow Catback, SLP Y-Pipe<br />Former owner of a White 3.8 RS<br /><a href=\"http://www.cardomain.com/id/allwhiters97\" target=\"_blank\">www.cardomain.com/id/allwhiters97</a>
Getting a message saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
