changing fuel injectors rails and all - FirebirdV6.com/CamaroV6.com Message Board
  • changing fuel injectors rails and all
    is it pretty easy to do? i have parts car with complete fuel rail injectors and all on the motor. how long do you think itll take a first timer. any specialty tools needed?
    I pledge aliegence to the flag that sits on the front facia of my camaro and to the Mickey Thompsons that make it stand two tires under torque indivisable
    Yes to all questions. You will need fuel disconnect tools& torque wrench good idea.Time consuming due to a lot of engine components need to be removed, but in the realm of a beginer.
    geocor
      Oh to time :did it on my '98 Camaro 3.8 approx. 4 hrs. with a little help & a few breaks.
      geocor
      • Andy H
        Transmission removal help!!
        by Andy H
      • 2.8 Bird
        Abs inop
        by 2.8 Bird
      • fishin
        by fishin
