Should I get the underdrive pully set? - FirebirdV6.com/CamaroV6.com Message Board
  • Should I get the underdrive pully set?
    ASP Underdrive Pulleys are CNC machined from billet steel or aluminum, exceeding factory quality. For 3.4L V6 Camaros and Firebirds, ASP has two pulley choices. The underdrive crank and underdrive alternator pulley set (49-541801) is only recommended for manual transmission cars and cars that are not running large stereo systems.
    I was thinking of getting a set but they said it is only recommended for manual cars. I have an auto. And I have a decent system in my car. Should I not get the alt. pulley or get a high output alt. or just get a capacitor?
    95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
    i have them on my car (auto) and i have never had a problem with them. buy i also have taken out my subs/amp so you may have problems
      I have a 94' 3.4 manual, ASP underdrive set, and a 1200 watt stereo system (1 farad capacitor). I've noticed that at idle, or 800 rpm the volts drop down to about 13 or so, but if you just tap the gas up to like 1000 rpm the volts shoot right back up to norm. I've never had any problems with the set so you should be fine. (the capacitor helped, btw) You should be able to feel the power difference with the pulleys installed, much quicker response.
      \'94 Firebird, 3.4 M5.<br />Arctic white w/ red anniversary stripe. ASP underdrive pulley set, Magnaflow 2.5\" stainless catback, CAT, Pacesetters, K&N FIPK2, 1000 watt stereo system capped 1F, Eagle Alloys 16\" 077\'s, 180 Deg. Thermo.
        if you're not sure, just get the ASP crank pulley.
          Thanks
            I'm selling mine if you want it
            <a href=\"http://www.cardomain.com/memberpage/512325\" target=\"_blank\">2004 Silver Impala</a> Faster than my Firebird<br /><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=282862\" target=\"_blank\">3.4L Red 1995 Pontiac Firebird</a><b> For Sale</b>
              How much are asking for you're pullies?
              ---Niño---<br /><i>95\' silver 5 spd</i>
                i have just an underdrive crank pulley , stock alt pulley, an automatic, and only a new head unit... i have no problems
                -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
                  It's just a crank, so I'll get rid of it and the belt for about $30
                    So I haft to get a new belt also? I will just get both pullies so what size belt will I need?
                      you need a smaller belt I forgot the size, I had mine for so long, I just took it in and asked the guy to give me one slightly smaller then this one...
                      I had some voltage problems with a stock stereo but my alternator ---&gt; battery wire was having issues... I never put hte alt back on, I gave mine to a friend and he hasn't had any problems on his car, he has no system but his car is a 5-speed.
                      In my opinion, buy them used, they don't exactly "go bad" and they are not that wonderful for what they cost new.
