Hey guys Im going to be doing AR stage 2 or 3 heads with intakes very soon. As my car sits right now with the cam in it my stock injectors are almost at max and I know by adding the heads/intakes setup that they will be out maxed for sure. I have in my room a set of GM 26lb injectors off a 99 Camaro SS. Will these be enough injector for the install to do the job. I will be ordering the injector connectors from ZZP so that they will work on my car. I am also considering finishing the fuel system with a Walbro fuel pump. Would that be worth it with that setup. I will also be puting in a Vig 3k stall and 4.10 gear soon.
26lb GM injectors
26lb GM injectors
01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
AR stage 3 heads/intakes to be installed
www.cardomain.com/id/firehawknwv
www.vaperz.com
PEWTER MAFIA/ Kristen's "PEWTER MAFIA KING"
Tags: None
Re: 26lb GM injectors
Actually I think the question I should ask is, what size injectors are you guys using. Im talking about those of y ou that have heads and ported intakes. Let me know that and that should help me find the right injector. Thanx.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
I said I was almost at max with those injectors. Read carefully UD, LOL. The HPtuners said I was at 90% duty cycle after we got done with the tune last year so I think we backed it off. Anyways I have the 26lb injectors as said and I will be ordering the connectors. Would a Walbro be a good addition to the setup?
UD by the way your package will be at my house tomorrow as it looks now. Thanx again for the part bud.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
How much power was you putting down before your turbo with just the heads and other mods.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
That will be what I will be running. Ill be NA for a while to come after all of this work.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
VooDo: I looked at the injectors and they dont say what brand they are, but Im thinking they are Bosch injectors. They are 26lbers form a 98 SS that I do know for sure.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
