Hey I have a few ?s about fuel issues. well I got a car from a place that took my car as a repo. well im trying to get it to run and I know the car isnt getting fuel So it could be a fuse or it could be the fuel pump. also what makes me think it is a fuse or switch is cause the car was sitting cause the tranny is shot in it... so i dont think the fuel pump went out while it was sitting. So what are somethings I can do to check? where are all the fueses for the fuel pump or fuel system?
PS when I turn on the car I cant hear the fuel pump. Also do this cars have a fuel shut off switch????
uhhhhhh yeah Im pretty sure its the right key well \ idk lol i can turn the car over and everthing turns on. So yeah I pretty sure it is the right key.
Just check the fuses first. Then if there good. Yes you need to get the pump. There are 2 an in tank and out of tank (I believe I may be thinking of my truck) but anyways turn the igniton on and see you have power. You do this by hooking a VOM to the connections at the pump itself. If its getting power the pump is good.
3 days ago
