How do you know if you have the y87 package?? Where are the codes located and what should they be....btw i have a 1999 camaro w/5spd tranny
Y87??
Y87??
<a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'sTags: None
This will be on the drivers door sticker as:
Y87. Look for it there. Y87 3800 V6 Performance Package
The Y87 3800 V6 Performance Package upgraded the vehicle with Auburn limited slip differential (same differential used on V8 models), 11.4" single-piston caliper rear disc brakes (same rear brakes as V8 models), a dual outlet muffler, a quicker 14.4:1steering ratio (same ratio as V8 models), 235/55-16 tires. The Y87 package also gave automatic cars 3.42 rear gears, whereas the manual cars kept the 3.23 rear gears.Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
Don't some regular f-body's come with the dual-outlet muffler without the y-87?3.73 gears ramair kit flowmaster is no more now BORLA cat-back 3\"catco cat<br />best et w/ flowmaster 14.8 best et w/ open borla 14.62@94mph :)best et w/ open borla and drag radials 14.4 at 96 o yea and a set of pacesetters
The limited-slip diffy for the Y87 package is the Zexel-Torsen rather than the Auburn mentioned above.
The code IS Y87, there is a reason it is called the Y87 package [img]smile.gif[/img]
Oddly enough the option code for the V8 option is Z28.SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
96-97 Auburn
98+ Zexel
This the same as the stock V8 cars.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by FirebirdGT:
</font><blockquote>quote:</font><hr />Originally posted by mjparme:
96-97 Auburn
98+ Zexel
This the same as the stock V8 cars. </font>[/QUOTE]Right, but he said he had a 1999.SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
