Engine check light came on. - FirebirdV6.com/CamaroV6.com Message Board
  • Engine check light came on.
    Hi everyone.
    My engine check light came on when I was driving in the high way. So stop by a local auto zone and rang a scan. They say that I have a P0108 and a P0137. I have no idea what this mean can some help me with this.
    Thanks.
    Re: Engine check light came on.
    This is what my Haynes repair manual says
    P0108: manifold absolute pressure sensor circut, high input
    P0137: oxygen sensor circut, low voltage (post-converter sensor, left bank)
    Hope this helps. later
      Thank marvelrunner for look it up for me. Do you guys know were does manifold absolute pressure sensor circuit, high input located and why this happened? Also how could I fix oxygen sensor circuit, low voltage (post-converter sensor, left bank, and why this happened? Could I still drive my car this problem and how long. Sorry that I'm asking so much questions.
      Thank.
        Do you guys think the cause of the manifold absolute pressure sensor circuit, high input to come on is do to a dirty air filter? Also you guys think the cause for oxygen sensor circut, low voltage (post-converter sensor, left bank) is do a 3" cat with an stock S-pipe on?
          Hey bigralph 2 I was reading in the Haynes manual to try and see if I could help but I need to know what year and engine type your car has. I will then either try to explain what the book says or scan the book and send you the images. I will try to do that later tonight when I get home from work. around 7:30 pm central time. Hope you can wait or that someone else can help. So just respond to this post. Later
            I also change my fuel filter like two weeks ago if that helps.
              yes your aftermarket cat can/will throw a code.
              2000 3.8 A4 Pewter Camaro
                change the MAP sensor and the 02 sensor.
                Follow me!
                Or this
                  Thanks everyone for the help. I have a 2001 camaro auto if that helps.
                    I already have a o2 casper sims after the cat.
                      Well I scaned and uploaded the pages from the Haynes manual and here are the links:
                      http://i16.photobucket.com/albums/b4.../MAPsensor.jpg
                      http://i16.photobucket.com/albums/b4...gensensor1.jpg
                      http://i16.photobucket.com/albums/b4...gensensor2.jpg
                      http://i16.photobucket.com/albums/b4...gensensor3.jpg
                      Hope this helps or gives you an idea of what to do. later
                        sadly o2 sims are hit and miss. some work, some dont, some work for a little, then go bad.
                        the post cat 02 doesnt have anything to do with how the car runs from my understanding, so its not a big deal.
                          Thanks marvelrunner for scanning does pages for me. I going to replace air map sensor and the o2 sensor this weekend. Thanks everyone for the help.
                            This sucks. I replace both the new map sensor and a new o2 sensor, and I still gave me the dam code of P0137. I know that isl the o2 sensor, but I think that I'm running rich. Maybe I'm wrong. Please help me with this.
                              Any surjection. My car feel really slow. Help please!!!
