help me 3.4s men - FirebirdV6.com/CamaroV6.com Message Board
help me 3.4s men
  • help me 3.4s men
    ok , on the wiring harness for the fuel injectors...
    ok, i have the wiring harness.. it has the big block connector.. i know where that plugs in...
    then i have a coolant temp sensor that goes in the thermostat housing
    the injectors
    a green plug with three prongs for the MAP sensor apparently,
    and another connector with 2 wires going into it, one of the wires is yellow and the other is black.. the connector itself is white/grey with a blue peice on the back and the dudt boot is dark grey
    what does that last connector connect to?
    1995 Camaro 3.4 M5 - Project<br />1998 Camaro 3.8 A4 - Daily<br />Aim:V6OnSpeed<br /> <a href=\"http://www.cardomain.com/memberpage/576233/1\" target=\"_blank\">http://www.cardomain.com/memberpage/576233/1</a>
    sifting through that, the IAT connector.
    but I could be wrong. How long is the lead for the connector?
    The bastardification of Third & Fourth gen cars.
      it doesnt go outside of the upper intake
        damn dude only thing I can think of w/ 2 wires up there is the canister purge solenoid valve(has 2 lines running throught), IAT, ECT(coolant sensor) and the Cam sensor. Sorry bro thats all I could think of maybe it's a connection thats runs to the ECM.
        ---Niño---<br /><i>95\' silver 5 spd</i>
          i was think the coil plate that the coils sit on there two plugs on the one side but i dont know about the other side i think theres a plug on that side
            post up if you do find out what it is, don't have my car w/ me right now or else I woulda found out for ya.
              On the ignition module there is two plug connections on the left side and one on the right side. The schematic diagram in the haynes manual says that the connector with the yellow wire is the engine coolant temprature sensor. But since you said you already hooked that up it may be something else. Ill go check my car in a little while and get back to ya. I know that the only sensors in my injection harness is the injector plugs and the ect.
                ur right i found it but got bigger probs
