Hard Starting issue - FirebirdV6.com/CamaroV6.com Message Board
Hard Starting issue
  • #46
    Re: Hard Starting issue
    correction,replace fuel filter and pump and the car still ****ing up
    • #47
      Strange, i have exactally the same problem. Mine is also a 1995 3.4v6. Just started happening all of a sudden, sometimes starts no bother then sometimes it cranks and seems like it's going to start then doesn't and dies. I joined this forum to try to get an answer but looks like this may be the problem. Exactally what do i need (not including tools) to order for a mechanic to install? Fuel pressure regulator....injector O ring things (i'm not mechanically minded.) an accurate list of parts would be extremely helpful :) Also, how long would it take to do (by someone who knows what theyre doing) just so i have a rough idea of labour charges?
      Also, will trying to start the car like this everyday make it worse so it won't start (don't want to get stranded somewhere) or cause any other damage to the car?
      Thanks
      Peter
      • #48
        I changed the FPR out and the car runs like a top again
        • #49
          I had the FPR replaced on my '96 3.8 and still have the rough starting issue. It starts a bit better, but the problem still remains.
          • #50
            I have the same exact problem with my 3.8 camaro man, my buddy told me it could be the cam sensor or crank sensor. I havent tryed to replace the sensor yet but when i do ill let you know.
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
