a/c eliminator - FirebirdV6.com/CamaroV6.com Message Board
a/c eliminator
  • a/c eliminator
    real quick, is there an a/c eliminator bracket for a '97 3.8 v6? i know other's have one, just wanting one myself.
    Re: a/c eliminator
    so... ill take that there isnt one...=\
      Re: a/c eliminator
      I have only seen ones for the 3.4l, I will look a bit more and see if I can find any
      http://www.bowtiev6.com/
        Re: a/c eliminator
        Found this one, it is for grand prix's but they have the same engine, so it might be possible to use it on our cars as well. Not positive though
        https://www.zzperformance.com/grand_...=558&catid=111
        http://intense-racing.com/ also has the same thing and has a note saying it works on fbody cars as well, some will need a spacer between bracket.
          Re: a/c eliminator
          thanks man, yeah just a second ago i found that one on intense racing. so i went searching for the one for grand prix's. couldn't find the site for some odd reason, but thanks for giving me the link. :D
            Re: a/c eliminator
            I removed my a/c, switched my idler pulley to a grooved one, and am running the belt for the non a/c cars. Works just fine.
            Representin' Team Red In The North
            Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
            Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
            Black/Red '02 Honda CBR 954RR Fireblade
              Re: a/c eliminator
              by idler you mean the a/c idler pulley? if so i might check into doing that instead. that could be why there isn't an eliminator for our cars... hahaha, thanks for that info dawizman.
                Re: a/c eliminator
                do what i did, remove your a/c and just get a smaller belt.
                  Re: a/c eliminator
                  that is what i plan on doing... but the idler pulley, did you put a grooved one in it's place? i can get a grooved one, and a smaller belt.
                    Re: a/c eliminator
                    i used the stock idler pulley
                      Re: a/c eliminator
                      so whats the path you took for your belt, since you didn't replace your idler pulley?
                        Re: a/c eliminator
                        well i also have an electric water pump, so i am missing the belt over that too,
                          Re: a/c eliminator
                          well that makes sense, i've already looked at a set up if i put on an electric water pump... but until then... if that even happens lol.
