ok, i put on my headers and i needed to change my spark plug wires. so, i got the NSD 8.5mm wires from ftpp.net. well, i didnt push #1 wire in on the distributor cap enough. so, i had a miss fire. got that fixed. still was miss firing and the #1 header tub still wasnt hot. so, i checked the connection to the spark plug and that was it. got that fixed but when i started up my car again, the engine was still shaking allitle more than usual and every once in awhile i could here this ticking or knocking noise. what the hell is going on?
I Have A Problem Guys
Tags: None
here is alittle more info. i have 73,000 miles on her. i had to change the egr adapter tube/ mounting bracket that goes to the header/manifold but i wouldnt fit in the hole so i cut the slake off. would that be it? could there just be a leak there that is causeing the tick? im going to have my fiancee get me a stethiscope(spelling) tomorrow cause she is a nurse and im going to try to find the noise. and i cant check to see if the spark plug wires are euring(spelling again
) cause my exhaust is too ****ing loud for a 2:20 start up.
i didnt let my car warm up cause im worried about damaging my car if this is a serious issue. also, the ticking/knocking was not close at all. atleast 20 seconds apart and i couldnt tell if it was like in rythem cause of it being so far apart.
any possible suggestions please. anything you might think of, i dont care where its located on the car. and i dont care how common or uncommmon
Is the #1 spark plug fouled?Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
i looked a the spark plugs w/ my fiancee's dad and he said they are fine but im not sureif we looked at everyone.
Ka50---i dont know what you are talking about so NO!! lol what is it and what are connectors?
Your suppose to put grease on the connectors in the wires to keep the spark from jumping(new wires should have come with it). However if my exhaust gets quiet enough I can hear my spark plugs firing (or ticking) always have. Also could the ticking you hear be an exhaust leak?00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
also. i didnt get any grease. i'll pick some up later today. do i put them in the boot on both ends?
Yup in the boots. Make sure its the right kind of grease tho lol.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
im about to jump in and redo the wires. i got some silicon for them from o'reilys
Sounds good that could be your problem if the spark is jumping at the connectors.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...17 hours ago
