Signs of a bad fuel pump? - FirebirdV6.com/CamaroV6.com Message Board
  • Signs of a bad fuel pump?
    Well lately my car hestitaes a lot when starting adn when it does the engine revs itself to about 2k then drops. Then back up. I changed the fuel filter and the plugs and wires checked out okay. Could I have a bad fuel pump? Whenever I get off of my car, there is this strong smell of gas. The cap is locked and everything so I am thinking fuel pump. Any suggestions? Thanks!
    98 Camaro V6
    Get a fuel pressure tester and check the pressure and how long it holds the pressure for.
    Matt
    1998 Mystic Teal Camaro M5
      My car had a terrible time starting when the pump was failing, and when it would start and get pressure tested everything was fine. Pump or FPR maybe!
        Had the same problem. Was the fuel pressure regulator.
        98 bird <br />160,000 miles<br />13\'s? Just happy it\'s starts every morning. <br /><br />Traded in @164,000 On a 2001 Formula
          6 days ago
