G/N Injectors - FirebirdV6.com/CamaroV6.com Message Board
G/N Injectors
  • G/N Injectors
    Searched and didn't find anything solid. Will the Grand National fuel injectors fit our cars, specifically a 2000 3.8? TIA
    Re: G/N Injectors
    what kind of pin style do they have? What size are they?
    http://www.bowtiev6.com/
      Re: G/N Injectors
      According to the seller they are 30lb from an 87 and the part number is part number 2110 25324366
      Ill see if Ic an do some research from that to find the pin count
        Re: G/N Injectors
        They are a saturated type with a resistance of 12 ohms if that'll help you tell me.
          Re: G/N Injectors
          reason I asked what style pins is cuz usually 00+ guys have to get the wire adaptors from zzp in order to upgrade injectors
            Re: G/N Injectors
            I posted the question over at FTV6 and I got some solid answers from them too. In short no they won't direct fit without rewiring or an adapter like you said. Not worth the trouble to me. I'm just looking for bolt on's not refabricate or reengineer. Thanks for your help.
              Re: G/N Injectors
              alright, good luck with the car
                Re: G/N Injectors
                Thanks I'm gonna need it. Finally trying to start the build I posted about 5 months ago so it's gonna be slow going. As I start getting into her more I will start posting up the progress.
                  Re: G/N Injectors
                  Can't you get Upgraded Injectors from Summit they have up to 24lbs./hr
                    Re: G/N Injectors
                    Yeah just trying to do the buildup as cheaply as possible. Used ones in good condition that I can just change out the o rings will be far less than new. I'm just trying to save buying new of anything for last resort. I'm a cheap SOB!
                      Re: G/N Injectors
                      what I did is I went with GTP injectors that were 50 bucks shipped and 36#
                      you having a new car though will still need the wiring adaptors from zzp
                        Re: G/N Injectors
                        Do you know the type of injectors I have for a 2000 3.8? Is there a list of compatibles that I could purchase? If I got some from a 2000 grand prix those should be good right?
                          Re: G/N Injectors
                          you have the multitec ones that have a different pinout than the GTPs from 97-03. I think the 04 l32 cars came with ones that you can directly swap into yours, but not positive on that. Best way to find that out would be going to clubgp.com and searching that forum as it is the grand prix mega forum. That is where I got my injectors from also
                            Re: G/N Injectors
                            Ok and if don't get ones that plug in I need to use a adaptor? I just looked through zzp and didn't see anything, can you point me in the right direction? Just when I thought I knew everything, lol
                            edit, I see now. thanks for the help again.
                              Re: G/N Injectors
                              Solution from my research is this. May be a good thing to add for future peeps.
                              Get injectors from a late model truck with a 4.8, 5.3 or 6.0, multec 2 injectors rated at like 48# @ 58psi give or take, my memory sucks. Get a pre 2000 fuel rail and bingo. The fuel rail is to compensate for the diff in height or you could cut down and weld what is there. The injectors will snap in and then all you need to go is get the comp tuned for it.
