Searched and didn't find anything solid. Will the Grand National fuel injectors fit our cars, specifically a 2000 3.8? TIA
G/N Injectors
Re: G/N Injectors
what kind of pin style do they have? What size are they?
Re: G/N Injectors
According to the seller they are 30lb from an 87 and the part number is part number 2110 25324366
Ill see if Ic an do some research from that to find the pin countLet's flip a coin. Heads I get tail, Tails I get head.
Re: G/N Injectors
reason I asked what style pins is cuz usually 00+ guys have to get the wire adaptors from zzp in order to upgrade injectors
Re: G/N Injectors
I posted the question over at FTV6 and I got some solid answers from them too. In short no they won't direct fit without rewiring or an adapter like you said. Not worth the trouble to me. I'm just looking for bolt on's not refabricate or reengineer. Thanks for your help.Let's flip a coin. Heads I get tail, Tails I get head.
Re: G/N Injectors
Thanks I'm gonna need it. Finally trying to start the build I posted about 5 months ago so it's gonna be slow going. As I start getting into her more I will start posting up the progress.Let's flip a coin. Heads I get tail, Tails I get head.
Re: G/N Injectors
Yeah just trying to do the buildup as cheaply as possible. Used ones in good condition that I can just change out the o rings will be far less than new. I'm just trying to save buying new of anything for last resort. I'm a cheap SOB!Let's flip a coin. Heads I get tail, Tails I get head.
Re: G/N Injectors
what I did is I went with GTP injectors that were 50 bucks shipped and 36#
you having a new car though will still need the wiring adaptors from zzp
Re: G/N Injectors
Do you know the type of injectors I have for a 2000 3.8? Is there a list of compatibles that I could purchase? If I got some from a 2000 grand prix those should be good right?Let's flip a coin. Heads I get tail, Tails I get head.
Re: G/N Injectors
you have the multitec ones that have a different pinout than the GTPs from 97-03. I think the 04 l32 cars came with ones that you can directly swap into yours, but not positive on that. Best way to find that out would be going to clubgp.com and searching that forum as it is the grand prix mega forum. That is where I got my injectors from also
Re: G/N Injectors
Ok and if don't get ones that plug in I need to use a adaptor? I just looked through zzp and didn't see anything, can you point me in the right direction? Just when I thought I knew everything, lol
edit, I see now. thanks for the help again.Let's flip a coin. Heads I get tail, Tails I get head.
Re: G/N Injectors
Solution from my research is this. May be a good thing to add for future peeps.
Get injectors from a late model truck with a 4.8, 5.3 or 6.0, multec 2 injectors rated at like 48# @ 58psi give or take, my memory sucks. Get a pre 2000 fuel rail and bingo. The fuel rail is to compensate for the diff in height or you could cut down and weld what is there. The injectors will snap in and then all you need to go is get the comp tuned for it.Let's flip a coin. Heads I get tail, Tails I get head.
