my stock 98 camaro is having problems.. at highway speeds and wanting to accelerate there is like a hesitation or studder then it will be fine... I'm thinking it is plug or wires, or injectors? not sure... what do you guys thind
problems
Re: problems
It can't be the plugs or wires cause when I had plug problems on the 97 it was all the time and this is only during acceleration. My wife actually drives this one. I am going to try the lucas fuel injector cleaner that I have here at home. I don't think I take as good care of this one car :( the 97 is my baby.... It hasn't had anything changed since she bought it 3 years ago... it has 82 k miles
Re: problems
97, please do me the favor and keep me updated on what you find out...i've been posting having this exact problem for over a week, and many suggestions have been thrown my way....especially the seafoam....probably will try that soon, just dont have the money for it...i know for me its not bad plugs or wires cuz i put new wires in a week ago and it went away for about 5 miles..and then came back...and gave me a misfire cyl. 1 code.....i checked #1 plug today..it was fine......removed each wire and watched the spark the other day too and they all were consistent, so i dont think its coils either..i think its a fuel problem and hopefully the seafoam will clear it up..if not...ill pray for the sensor...if not that....good god
anyway, keep me posted as to what u find out, and ill do the same
good luck
Re: problems
You have to give a little more info on the problem so someone can be able to pin point what it could be a bit better,does it happen only @2000 rpm,If you accelerate slowly to wide open Throttle does it still occur? Engine Temperatures have something to do with it? You have to do more test or driving trials,It could be Fuel pressure,Out of Phase Throttle position sensor,Partially Blocked Fuel Injector,etc.
Re: problems
I seafoamed today..it didnt clear it up...im trying a fuel filter probably tomorrow....i have it, just need some time to put it in...like posted in a different thread :
it is WORST at very low RPMS trying to accelerate, such as moving from an on ramp over on the highway...where the engine really needs that power....it will sputter and jump around on its way up to high RPMS but when it gets there its pretty good....idles fairly decent for the most part, so its mostly when the engine really needs that oomph, or when accelerating hard
Re: problems
Try plugs and wires. If you had bad wires or plugs and left them for a long time, it might cause the catalytic converter to mess up. Happened with my old 95 3.4 I would try to accelerate ad it would sputter, kinda like it was clogged. Try to smell your exhaust and see if it smells like anything. Bad garbage smell means your cat has gone POOF<a href=\"http://www.cardomain.com/id/1995birdman\" target=\"_blank\">http://www.cardomain.com/id/1995birdman</a>
Re: problems
same thing eazy e said..i changed them a long time ago and it was good..for like a month...then the problem comes back...eazy...any idea?.....im thinking its fuel related since the ignition changes dont work...but...it is interesting that plug or wire or both changes does cause an improvement..even though it doesnt last long.....any thoughts guys?
Re: problems
Well I took it to the dealership.... bad idea. but I have no time, I work 45 hours a week and go to school for 9 hours on both my days off. So I had no choice. 510 for plugs, wires, and fuel filter...ouch.. I know, I know I should have done it myself but what is done is done. both plugs and fuel filter I know take time even though some of you think it is cake. you are lying everyone should admit plugs on our cars are a pain. Car runs good now
Re: problems
lol...wow...fuel filter i just changed on mine the other day...filter costed 8.00 and took me 40 mins, including time to jack up and put away all materials....
plugs are 2.88 each....theres 15....and wires...$50 if you get a good set...so we're talking $75 or so...plus 40 mins fuel filter...1 hr plugs and wires....so you basically paid $75 for parts and $290 an hour for someone else to do it...bad call brother
