window motor problem - FirebirdV6.com/CamaroV6.com Message Board
  • window motor problem
    I just installed a New window motor in my 2000 camaro. It was the driver side and everything went well until i tested it, when it goes down it has like a popping noise. I greased up the tracks and all and still nothing but anyways heres a video i took so you guys can hear it
    http://s171.photobucket.com/albums/u...t=MOV00668.flv
    These were also EBAY motors, but i dont think it should make a differance
    Thanks, input of all is appreciated
    -Chris
    Re: window motor problem
    mine does the same thing, but i don't know what it is either :(
      feel around and find where it is popping.
      2000 3.8 A4 Pewter Camaro
        Make sure that thing is tight in there. When I did mine last week I didn't tighten it enough and it was doing the same thing.
        1999 Bright Red A4 3.8L V6 Camaro
        http://www.cardomain.com/ride/2589653
        http://www.myspace.com/jhonathanw
          So i ended up just keeping the motor in and puttin the door back together, it quieted down with the panel on, it just "pop" when i press down. It appears that the bracket u screw the motor on it moving in and out at least the rivits that hold it are, so now im uncertain as to what i should do. Any suggestions?
            it is normal for that to flex and for a popping noise to be heard with the door panel off. its really up to you to decide if it is still too loud with the door panel on.
