Like I said, I am having random RPM climbs when I start on occasion.
I go to turn the key, and the engine rools over usally like it is barely starting *putt putt* and then .. vvvvrooooom all the way to 2500. Hold there for a half second then drop back down to regular idle.
No idea whats going on, any assistance would be appreciated.
~Taylor
You Samoans are all the same...you have no faith in the essential decency of the white mans\' culture.
Upgrading to Bosch PLat Plugs and Taylor Wires soon but I don't think that would be the problem.
Why would a faulty spark cause the rise in RPMs when I am not giving it any throttle? My guess is it is a bad sensor somewhere but I have no idea what sensor it would be.
~Taylor
This might be kinda far fetched, but whats the weather like where you are? It sounds like it might be some kind of choke? When I start my jeep (it's still cold in NY ) and it's cold the rpm's always stay high for anywhere from a few seconds to a couple of min's depending on the outside tempature. Then again I just looked at your sig is it ever cold in houston?
[ March 18, 2002: Message edited by: liquidonyx ]
[ March 18, 2002: Message edited by: liquidonyx ]</p>
1994 black camaro 3.4l m5<br />18\" chrome rims 235/40r18<br />Shaved door handle\'s and emblems<br />wings west ground effects <br />harwood hood, custom interior
actually that cold weather thing isn't too far fetched. I took a trip with my car up to Idaho this winter and it was really cold. When i started my car up the rpms would rise for a little while then go back down. sometimes it would even repeat this process. Down in cali where it's warm this has never happened.
2002 camaro SS 6 speed, black, with black leather: Whisper lid/filter<br /> 98 silver camaro v6 a4(sold)<br />few mods
Is that a normal temp where you live. my brother went to tech school for the USAF in lackland and he said they went 20+ days with the temp over 100 degree's last year?
Could it have anything to do with filling up with a different gas. I hear that putting gas with a different amount of octane in your car causes your car to run different for a while till your computer adapts. The only other time that ever happens to me is right after i change my oil.
I have had the exact same problems as you with my 94 v6. I put on a flowmaster muffler and my exhaust popped, and soon afterwards i experienced the starting problems with the rpms you mentioned. as far as the exhaust goes there really isn't anything you can do about it except maybe a cutout after the cat. When i had problems with the rpms after starting the car the problem seemed to fix itself after a few days. If that doesn't work disconnect your battery and let it sit overnight to let the computer reset itself.
My Old IROC had this problem, was a prob with the TPS, I adjusted it and it worked ok for a few days then started having the problem again. I replaced the sensor and never had a problem again..
