Door Problems - FirebirdV6.com/CamaroV6.com Message Board
Door Problems
  • Door Problems
    When i open my door it makes a squeaking noise. When i noticed this I also noticed some of the paint is scratched on the door sill. I dont know if those scratches were there before. Any doctors in the house want to help me out?
    There is fast, too fast, and way too fast. Way too fast is almost fast enough.
    Use WD-40 on the door hinge. It happens.
    2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
      my door sags a little, when I shut it it seems to clunk then shut. where could I get new hinges, would a junkyard be a good place or ?
      96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />&gt;&gt;&gt;15.375 @ 89.27&lt;&lt;&lt;NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
        I've never seen a 4th gen fbod in a junkyard. Don't know if they will fit, but try 3rd gen hinges
          Door sag? Just replace the bushings. I'm thinkin that the hinges are weleded to the body so I would avoid that. Bushings aren't that bad. Just place a floor jack under the door to support the weight. Then have somebody hold the door in place while you knock the rods out of the hinges. Then knock the old bushings out and replace them with new ones. Make sure you pay attention to the how the old bushings come out, so you can replace them right. Then wrestle the door back into place and carefully knock the rods back into the hinges. It's relatively easy with an extra set of hands.
          ~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
