One day last week i went to go take off, and floored it from a stand still. Once i got on it, the car started to shake pretty bad, so naturally, i reproduced the shake and realized it was coming form the right rear. Sicne i have a v6 and dont have lsd, i realized that thats my driving tiring, the one that is doing most of the work when i'm skidding...
Also when getting on it at a low speed and u will just peel out and you can feel it skipping along the ground unable to get traction.
Well when checking it out i noticed my right rear shock was going bad so i ordered up a new set of bilsteins and today i installed them in the rear. Checking everything else while i was down tehre and everything looked fine. Yet, today when i went to go and test it otu to see if it would still have traction problems, it still does.
I dont know what the problem could be now, also the right side of my car is sitting almost a full inch lower than the other side. I noticed this before the shock replacement, but now its still lower to the ground. anyt suggestions on wat this would be? did i screw up my spring somehow? orr is it lca's related, any help would be much appreciated also, could it be axle related or something to do with my gears? or even teh driveshaft b/c its a two piece.
