Weird sound - FirebirdV6.com/CamaroV6.com Message Board
Weird sound
  • Weird sound
    It's a slight ticking sound, and kind reminds me of lifter tick, and seems to be coming from somewhere under the hood, but I'm not sure. I'm 99% sure it's NOT lifter tick though, because the speed and intensity of the sound decrease with more RPM, they don't increase, as lifter tick does. Plus my lifters are only 10k miles old.
    It also sounds like it could be an exhaust thing. Maybe a header leak? I occasionally hear a faint "pop pop pop pop" sound coming from the exhaust. It's hard to describe.
    Maybe it's nothing. I was thinking it could also be a belt tensioner or something. Any ideas?
    Forgot to mention: NO codes, and absolutely zero performance problems.
    Re: Weird sound
    well i dont think it is an ehaust leak because im pretty sure the ticking would get more frequent with higher RPMs
    so you can cross that off your list
      Re: Weird sound
      I have the exact same problem and it drives me insane. I can hear it at idle. Sounds like its coming near the engine/headers area. Then when I press on the gas it goes away after it goes up a few hundred rpms.
        Re: Weird sound
        same here lol
          Re: Weird sound
          Well I still haven't figured it out, although I don't think it's anything significant.
          My fuel pump went out, had it replaced, and it still makes the noise, so it wasn't that. I hate this sound.
            Re: Weird sound
            Could it possibly be that the oil isn't circulating quite well at low rpm's?
              Re: Weird sound
              i have this problem too. ticking ONLY at idle from inside the engine bay. its not all the time though, but pretty frequent. can our valves be adjusted without taking off the covers?
              Car also seem to be chugging gas, but maybe im just running it too much ;)
              1999 v6 Camaro M5
              Automatic to Manual converted
              Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
              !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
                Re: Weird sound
                The springs, retainers and seals can be adjusted/replaiced without taking the CYLINDER heads, but not the valve heads...
                  Re: Weird sound
                  I have the noise, but most of my valvetrain is brand new. I have new springs, retainers, pushrods, and lifters. I don't think it's a valvetrain thing.
                    Re: Weird sound
                    my fiance has a "wierd noise" in her 96 3.8 vert as well - but not like you guys are describing. when she brakes or turns right (weight shifted to the left side of the car ) there is a knocking noise, like something is rubbing somewhere - cant figure out where cause its not apparent at idle or at low speeds.
                    thought it might be suspension, but it doesnt happen all the time..any ideas?
                    hybrid - \'\'hI-br&d - The offspring of a cross between species.
                    Co-Founder West Coast F-Bodies
                    West Coast F-Bodies Car Club - WCFB Message Board
