taking off dash pad - FirebirdV6.com/CamaroV6.com Message Board
taking off dash pad
  • taking off dash pad
    Part of my dash pad broke around the defroster and when I tried to attach it back, it looks real tacky. I was wanting to pull the dash pad off and sand and paint it. I just don't want to break any more of it. Any help on how to would be great.
    96 Firebird, Ram Air Hood and Airbox, Magnaflow Catback & hi-flow cat, Dynomax Bullet muffler
    It's got little clips, you just have to pry a corner up and carefully pull it off.
    g
    2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
      Start with the passenger side and use a long flatbade screwdriver to push the middle tang in, on all the clips. The push up the pad, area by area. The pass. side has alot more give than the driver's side, and so it's alot more forgiving to removal. BUT, be very, very careful, if it's not been taken care of, it will be more brittle than Kernal Sanders corpse.
      <b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
        Yah, mine had a small crack and within two days was a basket case. You can find them on ebay for about 40 dollars. The front of it at the base of the windshield is held on with velcro. I assume we are talking about the dash pad. The big plastic piece with the defroster vent in it.
        Jessica :)<br />Kansas: There\'s no place like home...99 Firebird Blown/6lbs, Eaton w/3.42\'s CI headers Z28 Exaust<br />CAI, #36 injectors Intense PCM
          To make it easier, when I took mine off I removed the pillar cover piece and just pried it up. Go slow like they said and it should do fine.
