belt removal? - FirebirdV6.com/CamaroV6.com Message Board
belt removal?
  • belt removal?
    <stupidity>
    i just read that GMHTP article about the 3800 v6 and they mentioned removed the air filter and serpentine belt and then wound up dropping 2-3 tenths off their best.
    </stupidity>
    edit: meh, lemme re-word this, wouldn't that be a BAD thing to remove the belt?
    [ March 18, 2002: Message edited by: TheBeast ]</p>
    Uh, just look at the front of your engine...
    Not to be too technical, but the serpentine belt is this flat bendy black thingy with grooves on one side; you can see it moving when the engine is running. :D :rolleyes:
    I solemnly swear I am up to no good.
      I dont know about you but the thought of going WOT without my waterpump flowing cool water past my heads isnt comforting.
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        yea...I had my belt fall off and I had to drive to the nearest gas station and my temp gauge was slammed into the red, and I was crusin' slow. I wouldn't want to think about runnin full throttle down a track with no water pump cooling my engine.
        <b>99\' Black Camaro SS</b> <br />M6/T-Tops - SLPLid w/K&N | Hurst Billet Plus w/ LSS | EGR Mod<p>Black 97\' Camaro T-Tops (RIP)
          I was looking into somthing like this but using a small belt to go over only the water pump. sould free up a few ponys
          99 firebird 3.8<br />ftra,custom made air box, pacesetter headers, 3500 pi vig verter 3.73lsd trans-go stage ii shift kit corvett servo flowmaster cat back dees tb spacer <p>_ ___soon___ _ <br />P&P heads 3 angle valve job and a nice cam to go with i
            of course it would... that's what U/D pullies are for. you're just talking about an extreme pully kit! don't forget the alternator
            1994 Camaro 3.4L M5 R.I.P.<br />You know what they say- a small engine means big... errr... e/t\'s<br /><a href=\"http://www.pbase.com/rrj72/the_accident\" target=\"_blank\">www.pbase.com/rrj72/the_accident</a><p>replaced with: red 97 A4 vert (my brothers as soon as i find my REAL replacement)<p>soon to come: 1969 RS/SS<p>\"All you need are the esentials: scented candles, massage oil, and Berry White write that down.\" -Van Wilder
              i ran my car about 20 min. with not alternator wire hooked up.
              anyone know how to measure a belt and relate it to its size? I am looking for AC, Pwersteering bypass.
                So is their a belt that anyone knows of that is small enough to just go over the crank, wp, and alt? so we can bypass the ac and power steering? I might be interested in trying this at the track :D
                1996 Y87 Camaro, 175.0 rwhp, 211.6 rwtq.....1/4 15.500@88.54 &lt;----- Needs work!!<br />-CAI, Custom bent S-Pipe, LS1 I-Pipe, Flowmaster 80 series, !MAF, manual fan switch, relocated trunk pop switch, 180 degree t-stat, More to come!<br /> <a href=\"http://camaro.wbisolutions.com\" target=\"_blank\">http://camaro.wbisolutions.com</a> <p>WANTED!!! Naked and handcuffed!
                • Andy H
                  Transmission removal help!!
                  by Andy H
                • 2.8 Bird
                  Abs inop
                  by 2.8 Bird
                • fishin
                  by fishin
