Rusted Parts - FirebirdV6.com/CamaroV6.com Message Board
Rusted Parts
  • Rusted Parts
    How can one go about loosening a rusted bolt? If I think that the bolts are fused together is it even worth messing with. In this case it is the two nuts for the fuel filter that are rusted together and I do not know if I should try and break them apart.
    Any ideas...
    Also an idea for the tutorial writers out there...
    Maybe a guide telling people new to cars general tips when it comes to working on cars with common problems that people will run into while doing maintenance work. ie. rusted parts, transmission seal.
    Things that are hard to do would be easier with a little insight...
    Re: Rusted Parts
    get some rust penetrator
    2000 3.8 A4 Pewter Camaro
      Re: Rusted Parts
      I like liquid wrench. Penetrators work wonders on tightly rusted bolts if you spray them a few times over a few days.
      i\'m not an ambiturner.
        Re: Rusted Parts
        I've found my favorite to be JB- Justice Brothers. think it's available at auto part stores and such. works a ton better than wd 40. there is another one but i'm blanking on the name..
        1996 Chevrolet Camaro
        1995 Buick Park Avenue Ultra
        --Appearance Moderator--
          Re: Rusted Parts
          pb blaster
            Re: Rusted Parts
            PB blaster.... then use a flathead or a scraper and try to scrape some of the rust off of it yourself...
            and with things like a drum... hit the drum with the hammer and watch the rust fall out, but hitting somthing like a fuel filter with a hammer would not be a god idea
              Re: Rusted Parts
              GM penetrator will do its job in meer minutes
                Re: Rusted Parts
                I didn't know GM made a penetrator. How much does it cost?
                  Re: Rusted Parts
                  I do not know. I get it free for work. Wouldn't bother myself using anything else
                    Re: Rusted Parts
                    Are the threads that are not exposed to the elements going to be messed up and rusted too once I unscrew it? Because if they are I will have no idea what to do... Im wondering If I should even mess with it...
                      Re: Rusted Parts
                      The inside threads are usually not rusted. I suppose they could be. When I replaced my fuel filter, the bolts were pretty tight in addition to the rust. Are you using one wrench to hold one bolt in place while using another wrench to loosen the other piece?
                        Re: Rusted Parts
                        I've always used pb blaster, but what's this about the GM penetrant. Any dealership have this will they sell it over the counter?
                          Re: Rusted Parts
                          Yes, they will sell it over the counter, but they will(at least our GM dealer) order it instead of giving you one of their own that they have in stock. The guy told me it had something to do with inventory and what not, that's why they couldn't just sell me one of their own bottles of the stuff.
                          And as for the inside threads being rusted, don't even worry about it. There should be zero percent rust on the inside threads, unless it wasn't tightened very well last time it was changed and was able to get moisture in it. But, I've never seen the inside threads rusted.
