When I floor my car it seems like its missing...but its not throwing any codes. I sea foamed it as well just to see if that might of been the problem and I took it out for a spin about an hour later and I floored it getting on the hwy and it felt fine and then as soon as I turned around it felt like it was missing again? Its so confusing. I checked my motor mounts cause I thought that was what the problem was and there fine. Can anyone else thing of what it might could be?
Im confused
Re: Im confused
Originally posted by Smoke Panthernone of the above would ever throw a code
Really all you can do, is check everything out, and make sure everything is in good condition and working properly, without having a code. But mainly, save yourself the time and just limit your search to the things listed above that could cause misfires at any random time.
Re: Im confused
Well I tried changing my plugs last night and then realized it was to dark but I was messing with the cylinder six spark plug and I just put everything back and I took it for one last ride for the night and it was running fine again it wasnt missing at all like before but when I turned around it started missing again. I did notice all the other 5 wires are 8mm and the 6th was a 7mm( the one I messed with). Would that have anything to do with it..or could it be my coil pack? Is there any way to test the coil pack?
