3.4L mini-starter - FirebirdV6.com/CamaroV6.com Message Board
3.4L mini-starter
  • 3.4L mini-starter
    I've been wondering about trying to find a smaller starter for a long time to help w/ turbo pipe clearance.
    Well I came across one that might work. It's off a late model big block chevy truck. The 3.4L have a staggered bolt pattern and this starter bolts up to a bare 3.4L block I have in the garage. I just need to bolt it up to my car and see if it engages the flywheel without a problem.
    It's a lot smaller than the stock starter and A LOT lighter.
    I will try and fit it this weekend and give an update.
    Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
    If it's off a truck, and much smaller, then it should have the torque you need. Good Luck.
    <b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
      Are you running you're exhaust piping above the k-member for this?
      Hope it works that would be hell cool.
      Those 3.4 starters weight a good 10-20lbs
      ---Niño---<br /><i>95\' silver 5 spd</i>
        Yea, I'm going to make my own custom headers that come down and go above the crossmember. I also have a tubular crossmember to help as well.
          I figured there would be more clearance with a tubular crossmember to begin with in that area since it's only the crank sensors and starter.
          Regardless goodluck with everything, especially those custom headers.
            FYI a 2000 or newer 3400 has a smaller starter than ours, and it should work fine
            -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
              isn't that a FWD engine though? And it's mounted on the "driver's" side?
