If I need a new fuel pump will the one from zzperformance work. Its a walbro that sells for around 125?? Its under the grand prie though
Fuel Pump ?
Re: Fuel Pump ?
yes it will work, get the universal kit though, not the 3800 specific as that is the grand prix one.
I have the universal kit from zzp in my car and it hooked right up
Re: Fuel Pump ?
Originally posted by 97rs4lifeyes it will work, get the universal kit though, not the 3800 specific as that is the grand prix one.
I have the universal kit from zzp in my car and it hooked right up2000 Camaro V6<br />I\'ve done nothing to my car worth note. :)
Re: Fuel Pump ?
yes it is a walbro high-flow one. It is the one that we all use when we look to mod our cars and need more fuel.
No tuning required for it though, just keeps flow up when you need it.
Re: Fuel Pump ?
Originally posted by AbaddonHow's the life span on those?
Re: Fuel Pump ?
Well crap. I got the tank pulled (no, I didn't cut the hole...didn't want to cut and slash the back open) and it wasn't a big deal. Now that I have the cup and fuel pump out, I have no idea how mount the fuel pump. I saw the HOWTO on this site but the guy that hosts it has run out of bandwidth for the day and the site is offline. ARGH!
Anyone have any idea on how to mount the pump onto this type of setup? I've heard many of the gang have ditched their cups which would be fine. I doubt the Walbro pump I bought would fit into this anyway.
Any advice would be appreciated. I'm wanting to get this project completed today. Also, if you DO ditch the cup, where do you mount the sender level because mine mounts onto the side of the cup? I've got a 2000 3.8L Camaro. Thanks!
For reference, here's what my fuel pump looks like:
Last edited by Abaddon; 06-09-2007, 12:07 PM.2000 Camaro V6<br />I\'ve done nothing to my car worth note. :)
Re: Fuel Pump ?
Nevermind. I got it installed. It just takes a little extra work to get it to mount properly without instructions. I'm about to take it out for a spin.
I'm not sure why everyone says it's such a PITA to pull the tank. It took awhile to get it down because I'd never done it before but it took two hours to put it back together. It took longer to replace the stock fuel pump with the Walbro than it did to put the car back together. (shrug)
Knowing what I know now...I'd probably just cut the hole next time, though. Heh!
I'll post some pics of the replaced pump mounted in the cup a little later if someone wants to see the finished product.2000 Camaro V6<br />I\'ve done nothing to my car worth note. :)
Re: Fuel Pump ?
yup it works i have 2 of them in my tankwww.turbov6camaro.com
1997 3800 Series II Camaro
Re: Fuel Pump ?
If you ever want to take your pump out again with the trap door it takes 5-10 min. Trap door is the only way I do it.1999 Pontiac Trans Am M6 Far from stock.....
Re: Fuel Pump ?
Well I just didn't want to cut my car all up. I still don't regret pulling the tank and I tested it before I put everything back together. Now that I know what I'm doing with it, I could probably do it again within a few hours. I just don't want to have to do it again for a long time.
I didn't realize how easy it was to change out the panhard rods. Most of the rear end on these cars is easily serviceable. I've got a lot more confidence now that I took my time pulling the car down for this update. It was well worth the effort.2000 Camaro V6<br />I\'ve done nothing to my car worth note. :)
Re: Fuel Pump ?
Originally posted by 97camRSI'm about to have to replace my fuel pump. Guess I'll be cutting it up, LOL
Go with the Walbro. It's a great pump. Consider replacing your fuel level sender while you are doing the pump. Those things are notorious for going bad and giving wrong indications. It's only about $60 or so and well worth doing since you are going to have the tank open anyway.2000 Camaro V6<br />I\'ve done nothing to my car worth note. :)
Re: Fuel Pump ?
just cut it and put the carpet back over it and you will never know it's therewww.turbov6camaro.com
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...3 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...6 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
