Are there any computer programs like Autotap, or any chips for the 3.4? Thanks
Anything to do computer wise?
95 3.4 A4<br /><b>Performance:</b> SLP CAI, Flowmaster 80-Series Exhaust, Catco High-Flow Cat, ADS Performance Chip, 160* Thermostat, TB-Bypass<br /><b>Appearance:</b> 35th Ann. Stripes, SS hood, Wings West W-type bodykit, Wings West wing, 17\" Chrome Firehawk rims, Chrome Inserts, Clear Corners, Decals<br /><b>Audio:</b>2 12\" Audiobahn Subs, 1400watt Audiobahn amp, Streetwires, Subthump custom box, Audiobahn door speakers, JVC headunit<br /><a href=\"http://community.webshots.com/photo/86905013/106283184LzOzZC\" target=\"_blank\">New Pic</a>Tags: None
Stay away from the viper venom module. Its pure crap and a major waste of money. It doesn't do a thing and can even decrease performance in some cases. Do a search on the board and you'll see all the information about it. Pure junk.
The jet modules, stage 1 and 2 are the only things left that won't cost an arm a leg. ASE or superchips do custom programming but you either have to send them your PCM or go to them and its not to cheap. Hypertech used to make a module but they discontinued it a while ago. Also custom programming is expensive unless you have a friend who is a mechanic and knows what he is doing. Even then I would only get the speed governor off if I were you. Custom programming is always expensive and what happens if you need to have your PCM replaced or reprogrammed. It sucks that hypertech stopped making theirs.
[ October 09, 2002: Message edited by: Skullcamaro ]</p>1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
How is the electronic shift improver working out? I have one sitting in my room I just don't feel like messing with the trans. unless it actually works. Thanks95 3.4 A4<br /><b>Performance:</b> SLP CAI, Flowmaster 80-Series Exhaust, Catco High-Flow Cat, ADS Performance Chip, 160* Thermostat, TB-Bypass<br /><b>Appearance:</b> 35th Ann. Stripes, SS hood, Wings West W-type bodykit, Wings West wing, 17\" Chrome Firehawk rims, Chrome Inserts, Clear Corners, Decals<br /><b>Audio:</b>2 12\" Audiobahn Subs, 1400watt Audiobahn amp, Streetwires, Subthump custom box, Audiobahn door speakers, JVC headunit<br /><a href=\"http://community.webshots.com/photo/86905013/106283184LzOzZC\" target=\"_blank\">New Pic</a>
i have a jet stage 2 module for my car. it didn't really do a whole lot. i got mine brand new from a performance shop in my town for like $135. it only knocked .10 off my 1/4 time so its not really worth the money.94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
I found a Hypertech power programmer for my 95 3.4 and it really pepped up my engine. I put in the programming then a K&N FIPK and my car's running better than it ever has at 120000 miles!!! :D :D :D I did have to give about $280 for it though. I think it was worth every penny. Better throttle response, more power, fans turn on at a lower temp, and I guess the speed limiter is gone (haven't tested that one out and probably never will). And you don't even have to get your hands dirty to install it! Can't beat that with a stick! :D I give it a [img]graemlins/thumbsup.gif[/img]95 Camaro 3.4L A4<br />Bosch plugs/MSD wires, K&N FIPK , Magnaflow catback, hi-flo cat, B&M Shift+, Dee\'s spacer<br />Kenwood KDX-859, eXcelon Amps, Infinity Kappa 3-way doors and Perfect10 sub<br /><a href=\"http://www.cardomain.com/id/harbins95\" target=\"_blank\">Behold, the raw fury that is known as the 3.4!!!</a>
