Where is F/P relay or fuse ? - FirebirdV6.com/CamaroV6.com Message Board
  • Where is F/P relay or fuse ?
    OK folks, I'm a long time camaroz28 guy and my son got his first camaro ,
    A 1997 Camaro 3.8 and we are fixing all the little things wrong and one is that even after replacing the fuel pressure reg the rail still drops fast near zero psi which causes a slow starting. I know from LT1 past that the rail needs to hold 40-50 psi , I assume the same applies ?
    So I want to run the car on pure injector cleaner but can't find a fuse or relay for the fuel pump, what is it called or how do you shut off the pump.
    Thanks for your patience as I learn these v6's.
    Re: Where is F/P relay or fuse ?
    fuse is same spot as the 4th gen z28's...
    see figure 2 & 3:
    http://www.installuniversity.com/ins...lacement_1.htm
      Neither my 95 TA nor my kids camaro have that fuse box, the under dash fuse box has none of those smaller relays or fuses.
        see figure 2 & 3:
        That's a 1999. Early cars have a different fuse/relay box.
        Raven
          According to my 1996 shop manual, fuse 3, PCM BATT, removes power from the Fuel Pump Relay.
          Raven
