Okay so being in ohio, its not unbearable to have a working a/c. it hasn't worked since i got the car 3 years ago and with a droptop i never bothered. tried to recharge it last year and it would blow cold for a little while, then back to the normal ambient air temp blowing out. any idea what could be the problem and/or how to fix? what should i be checking for?
what's wrong with my a/c?
Re: what's wrong with my a/c?
sounds like a leak... probly back from your seals on the back of the compressor. idk if you have a "ice cold air" there, but its pretty muchjust a a/c shop. bring it there, have them check it, or fix it. i just had them check it bcuz i can get parts cheaper than most shops can, turned out i needed a compressor, and i got to replace my ENTIRE system for 300 dollars, your lookin at 400-500 bucks.
I'm with Scott on this. Take it down to your local mechanic and have them scope it. They can either inject some die into the system and look for leaks or they can use a sniffer and find it. You'll know more about what needs to be done once they tell you where the leak is.
If it's the compressor, it's going to cost you a little sum. If it's just a simple leak they may be able to replace a little rubber ring and recharge the system. You'll need them to find the leak first.2000 Camaro V6<br />I\'ve done nothing to my car worth note. :)
