how do I fix this. My security light has been coming and my car will not start some times. I have to wait 5 minutes and it will start.
firebird security light
Re: firebird security light
I have that problem occasionaly also. Light comes on and you cant do anything to the car...
Although i got the trick down...Keep turning the key really fast and sometimes it will turn over(well at least on my car)1994 firebird red t-tops 115K miles. needs paint job badly<br /><br />1993 camaro - gone<br /><br />1995 camaro - rdy to be drivin :)<br /><br />1987 camaro - slow *** v8 - blew it up ha
This sounds similar toa problem I had in my 97 Camaro. I eventually had t have my key tumbler replaced. Apparently on mine the wire connection, or something like that had deteriorated over the years and since it was not making the proper connection it was causing my factory security system to lock up the car and keep it from starting.
Search like mentioned. common problem with our design
Originally posted by Joey41This sounds similar toa problem I had in my 97 Camaro. I eventually had t have my key tumbler replaced. Apparently on mine the wire connection, or something like that had deteriorated over the years and since it was not making the proper connection it was causing my factory security system to lock up the car and keep it from starting.
