my driver's side door skin is comin off...looks like it had broken at the seam and someone glued it up. is spot welding at the seam the best way to fix this without gettin a new skin??
My Door is Seperating!!!!!
Re: My Door is Seperating!!!!!
my buddy had that on his 99z28. he used some sort of glue and its fine now. ill ask him next time i see him what he used.
Follow me!
Or this
Epoxy is the best, but proper surface prep will be key.
Lightly scuff sand both bonding sides with around 220 sandpaper or maybe a maroon scotchbrite pad to get a good surface.
Clean both surfaces with alcohol - you can get 90% or 99% isopropyl alcohol at the drugstore. Let the alcohol flash off for about 10-15 mins before you try to bond.
Make sure to be anal about the epoxy mix directions - going too far off the ratio will reduce bond strength.
Clamping is also a good idea if you can set it up. You might even want to pull the door off the pins so you can get it horizontal so the epoxy doesn't run.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
you can go to a body shop and ask them what type of glue they use. This is part of how our cars are put together. The door skin is supposed to be glued to the door frame.-Brad
2000 V-Star Custom 1100
:rock:
Originally posted by zlexissEpoxy is the best, but proper surface prep will be key.
thats it /\/\/\
epoxy ftw. couldnt remember the friggin' name of it.
Follow me!
Or this
Originally posted by 95astrovanmy driver's side door skin is comin off...looks like it had broken at the seam and someone glued it up. is spot welding at the seam the best way to fix this without gettin a new skin??
epoxy is definately your best bet.2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
well the door is back together...used some green scotch epoxy. dressed up the surfaces with a grinder and drilled holes in the inside frame for the epoxy to ooze through and "grip" to. now i just have to get my window straight. the lil pin on the window cradle thingy that rides in the track up and down is bent so it comes out of track. thats subject for a different thread thou lol thanx for the advice guys.
-Steve
