So I had to replace the body of the mirror on the passenger side because it was broke. So I went ahead and pulled off the driver side to repaint both of them. When I did this and put it back together, one direction on each of the mirrors doesn't work, but it did prior. I know there are some screw things that the motor works on, but was wondering if there is some special way you have to put it back together if you ever take it apart. Thanks
power side mirrors
There are 2 threaded plastic dogbones that attach the mirror to the motor. If both are not installed correctly, you get what your going through.<b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...4 days ago
