About every two or three weeks I'm adding water to the radiator since is loosing about 2 inches of coolant (That's what I can see when I remove the cap). However there's no dripping on the floor, and I am not seeing stains at the hoses, or the radiator. But after running the engine, there's a coolant smelling.
Coolant leak without dripping
Re: Coolant leak without dripping
Is the coolant smell comming from the exhaust, or from the immediate area of the engine bay?Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
Originally posted by Smoke Pantheryea, i'd skip the second post and pull the dipstick or open the oil port to see if the oil's breaking downCamaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
Originally posted by CDNFBIs the coolant smell comming from the exhaust, or from the immediate area of the engine bay?Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
I'm assuming you have a 3800.
If you using dex-cool as the coolant (as I am), I noticed that even with the smallest of leaks, and I'm talking small, little drops here, that the leaked dex-cool comes in contact with anything hot it will slowly evaporate or boil (depending on how hot the surface that it is contact with) and produce a very noticeable smell. Man I can smell the smallest amounts from quite a ways away.
Smelled the dex-cool comming from under the hood of a 05 caddy STS, spent so much time looking for that leak. Wasn't leaking onto the gound or anything, but sure could smell it. Drove me nuts. Finally found the upper rad hose, where it routes under the radiator shroud had a small pin hole, only big enough for the coolant to sweat out drop by drop. Replaced the hose and the smell went away!
But more current to you, check the water pump like larrymo suggests, but also look at the thermostat bypass elbow. Its a small plastic elbow that is located on the front of the engine, right where the thermostat is, and connects to the belt tensioner body. They are notorious for cracking and leaking on the 3800s. To get a really good look at it you can use an inspection mirror and flashlight to see if there are any traces of coolant leaking from and collecting in the area.Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
I bet its the lower intake manifold gasket. Its dripping onto your head and burning off real quick.
Apparently mine was leaking for the longest time and I didn't know. I was having to top off about a quart or so everytime I got an oil change. No signs of leaking either, just like you.
Go get a pressure test done. They are pretty cheap and it'll tell whether or not you have a leak.
If it turns out to be the lower intake gasket leaking I hope you have a buddy that can do some work for you because it will cost a pretty penny to have it done at a shop.
Good luck bro.
-Beav1999 Camaro V6 3.8L A4<br />Red, T-tops, Monsoon<br />No mods.......yet.
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
