what kind of gains with... - FirebirdV6.com/CamaroV6.com Message Board
  • what kind of gains with...
    ok my car is pretty much stock, is all i have is a v force muffler with dual tips, stuff i am getting put on is:
    slp CAI
    whisper lid
    k and n
    LT1 stock catback w/dynomax bullit muffler in mid pipe and the lt1 stock muffler??
    texas speed tune!! sending my pcm off(10-15hp they said)
    will i notice good gains out of this, btw i just got zr1 chrome 9.5 rims and it feels like i have lost a little power?? is it just me or is this possible, also will i beable to edge out a 4.0 v6 mustang??
    good gains, yes. the feel of power loss is expected because you put on larger wheels which takes more power to move. and yes you should beable to edge out a v6 mustang
    2000 3.8 A4 Pewter Camaro
      Agreed. However I personaly wouldn't waste time on a stock LT1 catback. They are fairly restrictive. A good quality 2.5inch cat back like the magnaflow or B&B would REALLY compliment your other plans and work well as a system. I would also recomend a high flow cat. You should see some very nice gains from this to help offset the extra rotaional mass of the heavy wheels.
      BTW, why would you want 2 mufflers on the system??
      Also, there is no 4.0L V6 mustang.
      1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
        ^^^Yes there is, its the 2005. I believe Stock LT-1 systems are 2.75 inches, bigger than 2.5 inches. I dont know if it will flow better though just because of the added diameter.
        Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
          Yep the 2005 v6 is a 4.0. The 2.75'' pipe will flow a little better than 2.5'' just don't keep the stock muffler.
            so 16s are best for draggin?
              the take off won't flow "better". Just because it CAN flow more doesn't mean that it will work better. Couple the fact that the 2.75 is uneeded with a restrictive muffler and he will see next to nothing over his own stock exhaust. The the whole confusing ordeal of adding yet another muffler to the mid pipe?
              Didn't think about the 05's.
                WHo said that? The lighter the better and for dragging you want a nice sidewall, for example, a 16'' wheel with a 245/50/16 vs a 18'' wheels with a 245/45/18 with the same weight, the 16'' wheel will be better because it has more of a sidewall. Smaller wheels also normaly have more weight towards the center vs a bigger wheel.
                  Thats exactly why most drag wheels are 15 inches and light. Less rotational mass and more sidewall to bite into the track.
                    Wow learned something new everyday, I always though people would want more tread than sidewall... If thats the case then why do people invest on big slicks?
                    1997 Camaro RS W/T-Tops<br />All Stock / 200 HP
                      contact patch is not the same as sidewall depth. Wide means more contact with the surface, more sidewall mean that your aplying more pressure to the surface. Take a 70 serise tire and press down in the center of the tire (just the tire not a mounted tire) and it will press easy. Now take the same width 40 serise tire and do the same. You can't even press it in. Low deflection sidwalls are good for cornering, not for launching.
                        I guess you are talking the big stuff like a 33x18x15 or something like that? Sometimes you need that size to hook your car. Power, weight, gears and more go into picking a tire size.
                          so i screwe up by getting a takeoff???
                            oh yeah i bought a dynomax bullit muffler/resonator i thought u can out this in the midpie to reduce rasp???? then have the muffler? another thing i have a vforce muffler on now, could i use the v8 piping and go to the resonator in the midpipe then to the vforce muffler??
                            i searched this stuff and i thought i knew what i was doing i guess i thought wrong?? please help i am starting college next week and am low on funds!!!
                              http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
                              thats what i got
