what kind of gains with... - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Why would you posisbly want to put yet another muffler in front of another restrictive muffler? You want to reduce the restrictions that are present in the system. Not add to them.
    1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> &lt;Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> &lt;Fbody Tech Articals
    • #17
      hbhracing should i put that dynomax bullit muffler where our mufflers go and on the stock v8 system just do away with that muffler, run stock v8 piping to the dynomax muffler??? i thought it was a resonator????
      • #18
        do you want my personal advice?
        Don't bother with the take off since the best way to use it is to replace the muffler anyway. Just do it the simple way and install a B&B or Magnaflow 2.5" V6 catback and be done with it.
        • #19
          money issue,i cant afford a catback, this is hwat i have a v8 takeoff, vforce muffler, dynomax muffler, z28 tips
          • #20
            sell it all and get something that will actauly work without a lot of work. YOu would have to install the take off, then put the V force (crappy) muffler on ect ect. By the time your done haveing everything welded you could have had a real cat back on there.
            • #21
              how far is kenner from lake charles deridder area, also i want something with a good low sound not just loud what would be good and with decent gains! not to expensive though!
              • #22
                If you really want to go cheep and get "decent" sound I would just slap a flowmaster muffler on your stock set up and be done with it. All of the running around and changing that you would be doing adding a different muffler to a take off would just be counter productive.
                I belive it's around 4 hours ish from Lake charles to New orleans. Not really sure tho. I don't know the area well
                • #23
                  Borla ;) ..highest flowing best sounding (IMO) cat back on the market..not as cheap..but you can get the rear section and then just buy a 3" I-pipe seperate
                  • #24
                    how much for just the rear?
