OK, I've noticed a ticking coming from my car. I tried to ignore it at first, thinking maybe it would go away. I hear it just fine inside the car, so it's pretty loud. I'm thinking it's a sticky lifter. Only way to fix this is to replace it, right? I just seafoamed about 10K ago, along with new plugs. Any other things it could be? It seems to be coming from the driver's side, right by the cowl. I'll try and get a sound clip tomorrow if I can. It's there when I first crank it up, and until the car warms up. Once it's warm, it goes away, but when I first start it up and drive away, you can hear it ticking.
great, engine ticking!!
Re: great, engine ticking!!
most likely a lifter ticking, could also be an injector or two that you are hearing as well as possibly an exhaust leak.
Seafoam is usually a temp fix for sticky lifters, eventually they will give out on most people even after seafoaming
wow that was cool as hell mein............. the photobucket video :D i had the same problem the other day, except the rad was leaking like mad .....gunned it up the street and noise went away so did leak.....now car is dead in drive way....so I am new to these but will be a active member on the board as soon as I know what I am doing
1. Sounds like lifter.
2. Probably ok. Mine's been ticking for 30,000 miles.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...3 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...6 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
